Forums > Frequently Asked Questions > Registry Entry Questions
1994 Ford XLT needing help
Thread Statistics:     Users to Post: 1   |   Total Posts: 1   |   Total Views: 2912
itsasnowbunny
• Aurora, CO, USA
• Registered on 4/28/2023
Posted:4/28/2023 17:55
Referred by SOMORRIS on F150Forum.com:
will stall when you off accelerator coming to a stop or slowing down for a turn ....
initial assessment fuel induction appeared to help but did not work....
removed and replaced EGR Valve ... (mileage plus fuel exhaust gas recirculation EGR valve and Carquest premium vehicle solutions idle air control valve) ... Did not work ...
remove & replace distributor assm (Duralast Gold Distributor Spacer) ....did not work ...
LOF 5W20 (Up to 6qts) Labor Oil change, replace filter, multipoint inspection, top off fluids ( where applicable) FVP 5w-20 PeakAll Season FVP filters engine and oil filter Wynns Oil treatment/friction Modifier and Wynns Oil System cleaner .... still did not work
Remove and replace PCM/processor assembly including component test
Cardone Reman engine control Module(ECM) - remanufactured
MY Vehicle still starts and runs BUT if you let off accelerator coming to a stop or let off accelerator to slow down to make a turn the Truck will die .... it will start right back up when you start it again .... I need some help ot advice because mechanics cannot figure it out .... HELP PLEASE! DVICE?
