TrickyTryler
Carlisle, PA, USA |
Registered on 2/18/2009 |
14 posts |
Posted:1/27/2010 10:15 |
Has anyone installed a shift kit on thier V-10 "X"?
I pull a 18' enclosed trailer loaded with cycles.
Plenty of hills around PA that work the converter more than I like, just thinking a shift kit might help it spend less time working the converter.
Looking for any comments. |
aklim
Hartford, WI, USA |
Registered on 2/20/2006 |
133 posts |
Posted:1/27/2010 10:41 |
If you give Brians Truck Shop a call at 870-422-3673, he can sell you a Valve Body. The install is simple. http://www.guzzle7pt3.com/bts.php
Also, you can call Jody at DP-tuner and have him put a tune on your PCM if you like,.
01 Excursion. Gauges with AIH Delete, AIS Air Filter system, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F6 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BDP Stage II AC injectors. Bilstein Shocks with U code front and A code Rear. Billet thermostat housing |
