2000 Ex how to: rear wheel bearing adjustment?
Thread Statistics:     Users to Post: 1   |   Total Posts: 2   |   Total Views: 870
7475ih
• findlay, OH, USA
• Registered on 4/29/2009
• 9 posts
Posted:1/22/2010 17:31
My parking brake hardware needs replaced behind the rear wheel hubs so I have to remove the hubs to do that and I was wondering what was the proper procedure for adjusting the rear wheel bearings when I reassemble it?
7475ih
• findlay, OH, USA
• 9 posts
Posted:1/29/2010 21:28
Well, I found out how to adjust the rear axle wheel bearings in case anyone needs this info later on? The rear wheel bearing retaining nuts work in a ratchet motion ,as they are turned they make a clicking sound. When installing the retaining nut it gets torqued to 60 ft lbs, and then you back it off 7 clicks for used bearings and 5 clicks for new bearings.Also note that the drivers side is left hand thread and the passenger side is right hand thread. You will also need a special socket to use on the nut.Its a really nice design because theres no guessing on how much preload to set the bearings at?
