Front End Brake Shuddder
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 981
DReaux
• H-Town, TX, USA
• Registered on 7/14/2009
• 18 posts
Posted:10/6/2009 11:14
Bought a used 2005 with 62K on her and I'm noticing a front end 'shudder' when I first apply the brakes. Only happens when at higher speeds (40mph +), then it settles itself out and brakes feel normal again.
Any idea what is going on? Will a disc brake upgrade eliminate the problem?
Thanks in advance... Derek
Founder & President of
The H.L.M.F. Syndicate
Subscriber since 1/1/2001
• 2,229 posts
1
Posted:10/6/2009 11:43
Derek - this typically indicates warped front rotors. The rotors probably became warped because at some point the lug nuts were not torqued to specifications when the tires were rotated. 165 ft-lbs is what I torque mine to and I have not had warped rotors since.
To fix your current rotors you can have them "turned" by a local shop or you can replace them. Depending on how many miles are on them and the condition they are in, it may make sense to replace them. Just make sure to torque the lug nuts on the wheels to 165 ft-lbs (or instruct your mechanic to do so).
Phillip Beall
• Honey Grove, TX, USA
• Registered on 11/7/2004
• 74 posts
Posted:10/6/2009 18:32
Derek,
I concur 100% but would add - When you do replace the front brakes, spend the extra bucks and have heavy duty rotors (preferably drilled) and heavy duty pads put on it. You will be amazed at how much better it stops.
Phil
DReaux
• H-Town, TX, USA
• 18 posts
Posted:10/7/2009 18:45
Derek,
Phil
That's the plan... I've looked into the drilled or slotted rotors. It take a bit of effort to stop a 4 ton truck!
Thanks guys,
Derek
